Yamaha Helm Master EX integration with TZT13X
PeterG
Hello, I am doing a new install and want to use two TZT13X units but it appears that they will not integrate with the Yamaha Helm master ex for AUTO PILOT purposes. I understand that the TZT16F is compatible with Helm Master but I want to have the faster processing of the Furuno XL series for 3D etc. What is the best way to have a Furuno XL system that integrates with Helm Master EX.
For approved Helm master EX integration with an MFD, you must have a HDMI port to display the provided HM EX video output. For the TZTXL series the TZT16x, TZTBBx, TZT22x, or TZT24x could be used as they all offer the required HDMI input. If an autopilot is needed the Yamaha proprietary pilot must be used which will work well with the TZTXL system.
Hello, Thanks for your quick reply....I was afraid only the tzt16F would work because on the yamaha side of things I could only find documentation (attached) for F series. Is there any documentation regarding interfacing TZTXL with Helm Master.
Many Thanks
TZXL meets the same requirements for this as TZT3. The newest version of XL also provides the optional Yamaha engine gauge layout so even the smaller XL can show the Yamaha layout without the HDMI input but to be "blessed" by Yamaha you must have an HDMI input so you can see the screen they provide. (looks exactly the same as of right now) They can change what they send over via HDMI any time they decide to change it. That is why they want you looking at the HDMI they provide.
Thank you for your information! I have a question about the transducers. Not sure if I should go to another thread.
We are planning on the 165T/275LHW-12p for 3D and Chirp(pocket mounted) Do we still need side scan?
We were thinking for side scan 455T-PR903(paired thru Hull)
