Winter project is to remove the long stem b 744 transcuder that is hooked up to my 15 inch TZT 2. Works at idle speed only must be mounted in a bad spot. What tilted element bronze transducers(600 or 1000 watt) will work
The full compatible transducer lists are found under the accessories of the TZT2 units on our web site. I believe the 600w units are still bottom discrimination compatible but the 100kw pre-tilt is not.
