My TZT2 has the most recent OS and software up date however I have been plagued problems overtime I update or change my waypoints.first problem is when I am on the chart screen and want to move an existing waypoint after I edit and move it the original way point is still in the original spot so I am left with two identically named waypoints in two different places on the chart. If I delete the original one I am left with only the new waypoint but I have on occasion forgot to delete the original point and wen I return since they both are identical looking except their location on the chart I don't know which one is the new one. Also isn't the point of being able to move a waypoint to move it? not duplicate it.
Second problem is when I go to my points list on the TZT2 I seem to have triple duplicated points. How do I stop this from happening? When I updated software last update with the most current version 3.01 I lost all all the points I had saved but after I lost them on the software update I up loaded the saved points back into the TZT2 from a USB drive I back up my points with.
The issue is now I have triple duplicate of every single point i have created and if I need to move an existing point the original point I end up with two identical points in two different locations. You can see what I mean in the photo. I moved point 24 now there are two instead of just the moved one.
My first thought was to just delete all my points at once after I back them up to my flash drive and reload them back in but everything I have backed up will just reload the same triple and double duplicate points. See photo
There is obviously an issue where the TZT2 is not able to move a point and is keeping the original point as well as the moved point. I also think that the TZT does not recognize duplicate waypoints when loading them from an external source like a flash drive it just saves everything even if it has the same exact name.
Is Furuno aware of this problem and if so will it be addressed in an up coming update?
