I have the C-Map SDVJNAM024MAP15.dbv vector charts installed on my TZT and I'd like to have more contour detail. Is this something that I can modify with the MFD to show more contours or is this a limit of the mapping product? In looking at the Navionics charts online, they appear to have contours every foot.
I also like to use the depth shading feature quite a bit and would like to know if it's resolution is based on the underlying chart. That is, if a higher resolution chart is used (less depth change per contour line), will the shading follow accordingly?
