Just upgraded to V8 and it went perfectly! The NMEA2000 interface to Fusion also works with no setup required. Thanks!
I tried to add Fusion as an ICON in the swipe down from the top selections and it appears that this is not currently possible. Just checking in case I missed something?
It can be added as a function gesture and may be a better method as you can make your Fusion adjustments and exit out and you are back to your previous screen. I'll leave it that way but was hoping to use the function gestures for other purposes. :jump
