Hello,
First thing you want to determine is what format the way points are in.
The TZTL12F requires CSV or GPX format.
You will want to import the way points into a navigational software
(Andren,Nobeltec,GPS Utility,ETC)
Convert the Lowrance points GPX or CSV files, Export them onto a thumb drive.
Afterwards you will insert the thumb drive onto the USB port that is located on the back of the TZT2 unit.
1.Display the homepage of the unit.
2.Select settings files and make sure to select the correct formats on top of the files menu. 3.Select import points and routes.
*you can only import and export through a USB Thumb drive.
Regards,
MR.RADAR
:furuno :
