Mehmet Okur
Any news about the new update?
Thank you.
Thank you.
Johnny Electron":1zwpree7 said:For this first week the wi-fi won't be active.
Johnny, this is huge. What is the process do this upgrade? The directions coming off the website are still the old ones stating to do a single display at a time.Johnny Electron":1bd00cts said:The positive is if you have three TZT3 units and can only access the USB port on one of them; that one unit will upgrade all three MFDs as long as they are at v3.01 (or v9.01 for doing TZT2BBs). (older versions will still need to access each MFD) So, hopefully everything goes as planned and the wi-fi will be active on 24 Oct.
seaquin, you should be able to go to v3.5 from v2.xx. You will have to use the USB update method to complete the update.seaquin":t6hgxkst said:can we go straight to v3.5 from v2?
gtstang462002":rkkeytsx said:seaquin, you should be able to go to v3.5 from v2.xx. You will have to use the USB update method to complete the update.seaquin":rkkeytsx said:can we go straight to v3.5 from v2?
https://www.furunousa.com/-/media/sites ... ctions.pdf
gtstang462002":2rkf82p5 said:Johnny, this is huge. What is the process do this upgrade? The directions coming off the website are still the old ones stating to do a single display at a time.Johnny Electron":2rkf82p5 said:The positive is if you have three TZT3 units and can only access the USB port on one of them; that one unit will upgrade all three MFDs as long as they are at v3.01 (or v9.01 for doing TZT2BBs). (older versions will still need to access each MFD) So, hopefully everything goes as planned and the wi-fi will be active on 24 Oct.
