wsp2
I've noticed the depth periodically cuts out. I'm not in very deep water - usually <30'.
It looks like the config in the TZTL12F isn't set up. The transducer is a 526TID-LTD/12. When trying to set it up though I'm not seeing that listed as one of the models. Two quick questions:
- Is there a compatible model I can choose from the list, or do I need to set this up manually?
- Might that be the cause of the depth cutting out periodically?
The transducer appears to be in a good spot ahead of the props and shaft so I don't think that's the issue.
