Tunacious Too
Hello,
I'm installing the following system in my Henriques 28 Express
2- TZTF 12
1- PG 700 heading sensor
1- GP 330B GPS Sensor.
1- DRS4D-NXT Radar.
I have a 526 TID-HDD transducer installed.
Question 1- The radar cable has a note saying not to bend more than 80mm. Is this absolute? I have a choice to leave the entire cable and connector outside, on the hard top or have a tighter bend, routing inside a 1.5 inch tower pipe. Which do I follow.
Question 2- The directions for the GP 330B says to install a resistor pin in the connector before plugging into the sensor. The directions mentions it is for 3DNN. Is this true for TZTF? I assume it is true because I will have a Can bus?
Question 3- What is the bend radius for the NMEA cable? I will be using the "light cable".
Question 4. Can I shorten the power cable to the TZTF? One display will be in a tower with a 20 - 30 foot run and the other has an 8 foot run.
Question 5- I will power the Can bus with a 12V connection. What size fuse should I use?
Question 6- How can I power the PG 700 sensor to test the install location. I think I need a male NMEA connector.
Question 7- I want to verify that the 526TID-HDD will plug into the back of the lower helm display? Correct?
Thank you in advance.
Bob
2- TZTF 12
1- DRS4D-NXT Radar.
Bob
