Hi, I'm new to the forum but I read your posts since some times.
I'm a boat owner in Italy and have a Furuno TZTBB system on board, recently I bought a Fusion Apollo MS WB675 radio with a remote control Fusion ERX400.
I know that the only way to interface them is to use the ethernet connection alone and setting the IP to fixed in the address range 172.31.xx.xx.
So I tried it and have set the IP to 172.31.16.6 subnet 255.255.0.0 gateway 0.0.0.0 at first. As soon as I have set the IP, the Tzt rebooted... and rebooted...and rebooted, always at approx. 65% of the boot up it starts again.
Therefore I tried another IP setting, 172.31.100.8, 255.255.0.0, gateway 0.0.0.0... no change.
Then 172.31.100.8, 255.255.0.0 and gateway 172.31.252.2 (taken from the tzt ip config).
Anyhow, whatever I tried, no difference. Always rebooting and no contact.
I have to say I connected the ethernet cables to the same switch where I have connected the two axis cameras (with POE), I don't know if this affects something.
Can someone suggest something i might try?
Thank you and regards
Renato
Renato
