Aggeloseco
Hello to everyone, somehow strange things happened with my tzt3. The current setup is TZT3 12 with TM265LM and P66 which I connect sometimes to tzt3 but mainly I use TM265LM. Before a week I had the P66 connected on the TZT3. Then I switched to TM265LM, the transducer was detected in the transducer list as TM265LM, the frequencies thought in dual freq mode was showing 50/200khz ( normally I get the 53/110khz). I checked, the preset 1 was normally set to CHIRP mode. The picture I was getting was absolute fine with very good resolution, as it should be with Chirp mode. But I didn’t like the thing that 50/200khz was showing on the screen. I restart the machine, same thing. Because the picture was really fine I didn’t tried to change something more. Today I decided to reset fishfinder settings. After that Frequencies went back to normal. I get the 53KHz/110KHz. I took a photo before the reset from fishfinder screen, and I place the gain offset and TVG where it was before. The thing is that, now I am getting a picture without good resolution. Before the bait was demonstrated very clearly with very good resolution, now the picture I get is very lower in terms of resolution as before. I will post photos from before and after ( 200/50 is before the reset, 110 if afterwards).
