Thanks in advance for any advice. Brand new to Furuno but love the system so far. I was searching through old threads, but couldnt find consensus on good starting settings. I've tried auto fishing/ cruising and rabbit holed a bit on manual. Im pretty sure I have the correct Transducer setup in the TZT12. All my network stuff is showing up in the NMEA which is good. Calcutta mounted the transducer in the correct well location.
I am struggling with keeping a clean bottom and I wasnt super clear on when to mess with TVG settings etc. If anyone has a good starting spot, Id be grateful. Im in Wilmington NC area and it seems Furuno is not as popular locally as some other brands.
Ive got good mapping/ waypoints, just trying to get the bottom set up right with a good split screen bottom lock for 100-150 ft. I took a few images from the waterway playing around with HF/LF.
The PBG feature is pretty slick, and maps clean. I havent figured out how to dial in the DFF3D just yet either. I wanted to get the basics down before jumping onto the next one.
Regards
Brian
Regards
Brian
