I am considering installing a TZT215 head unit but have to do so before planning and installing a full NMEA2K backbone. For the present, I only have one NMEA2K device to interconnect with the TZT...a non-Furuno AIS unit which is mounted about 4ft away. The plan is to create a (very) small NMEA2K backbone to connect these devices...effectively a couple of terminators, a couple of tees and as short a length of backbone cable as possible. Short drop cables will connect the devices to the tees.
My question is on powering the NMEA2K bus. Will external bus power be required for this very small network or can the TZT2 or the AIS unit provide the power needed? If an external power supply is needed, what would you recommend?
I can alternately connect the AIS via NMEA 0183, but it seems a shame to do so with both devices having a free NMEA2K port. Obviously, I would like to minimize cost and complexity on this interim solution...at a later time a robust NMEA2000 network will be designed and installed and these devices integrated to it. Are there other options I might consider in the meantime?
Regards,
SteveCo
Regards,
SteveCo
