Tzt2 transducer help
Ant
Hi there I currently have tzt2 worth the standard 600w transducer transom mount fitted in aluminium plate boat.
I need some expert help.
I am wanting something to produce good results in 100m to 250m of water
It’s all over my head abit. Is there something I can use that won’t cost a absolute
Fortune and without buying extra boxes. Cheers
You should upgrade to a 1kW transducer. The least expensive option would be a transom mount 525TID-TMD which has a list price of $650.. If you go thru hull the stainless models will cost more.
