T
TeamRezoned
Good morning,
We have replaced our old Navnet VX2 with a TZT2 and I am in the process of setting up a NMEA 2000 backbone so that our autopilot, heading sensor, and GPS/Radar can all share data. I would like to make sure I have the right plan for how to proceed to ensure that we are able to utilize the full capabilities of each component (Navigate-to, Sabiki mode, radar overlay, etc.)
System Components:
Navnet TZTouch 2
DRS4D NXT
PG700 Heading Sensor
FAP 7002 Processor Unit
My NMEA 2000 backbone consists of 4 Micro T's and terminating resistors on each end. Below is how I plan to wire the system:
T # 1- to TZT MFD
T # 2- Power Tap to Battery
T # 3- To FAP 7002- Hardwired directly to TB 11 on the processor unit
T # 4- To PG700
In addition to confirming that the above setup is correct, I have a couple more questions:
1. We previously had the 711C/PG700/FAP 7002 installed as a stand alone unit, not networked with the GPS/Radar. We cut the plug off the heading sensor and wired it directly to the FAP7002. When we did this, we had to use a power jumper from TB1 to TB12, as well as use a small resistor to bridge 2 of the wires at the processor unit to properly terminate the signal. If the FAP 7002 is tied in to the N2K network, is there any need for the power jumper and resistor, or can these be eliminated?
2. We are using a new NMEA 2000 cable to connect the PG700 heading sensor to the N2K backbone because we had to cut the connector off of the original cable to wire it directly to the FAP 7002. The N2k cable we are using has a male connector on the side that is connected to the PC700, and a female connector on the side that is to be connected to the N2k backbone. The N2K backbone Micro T's appear to be female, so they only accept male connectors...... is it acceptable to use a gender changer similar to "Actisense® NMEA 2000 Micro Gender Changer Cable (male to male)" to accommodate this connection?
Lastly, Which settings will I need to adjust in the TZT2 and 711C so that they are pulling the needed information from the N2K network?
I am looking forward to hearing your input. I have already learned so much from this process and appreciate the wealth of knowledge provided by this forum!!
Thanks in advance,
Dan
System Components:
Navnet TZTouch 2
DRS4D NXT
T # 1- to TZT MFD
T # 4- To PG700
Thanks in advance,
Dan
