TZT13xl Transducer
bhp
I am replacing 8-10 year old Raymarine system with a pair of TZT13xl's. Any recommend for a transducer ? Mostly salmon trolling in 100-150' max 250'
I have a B175HW (They say its Good to 500') running on my TZT13X . Just operating in auto mode. I also have the scx-20 and need to figure out how to level out the jagged bottom. Lots of things to learn with the new system. The picture is in the CA delta Sturgeon Fishing. Hardly ever see them stacked up like this.
1kw HW Airmar is fantastic for salmon. I feel the 1kw M element is a good compliment to the HW for a second transducer.
Go to the Fish Finder menu and look for "Heaving Correction" and make sure it is turned on. If that does not work or if it is greyed out, you will need to check the settings for the SCX-20 to make sure it is sending out the heave correction PGN on the network. To do that, go to the Initial Settings menu and scroll down until you see Network Sensor setup and the SCX-20 under that. Select it and it will take you to the SCX-20 settings. Then go to the "Input/Output" settings tab and make sure that "Heave" is enabled.
It works quite well and is very noticeable when turned on.
After turning Heaving Correction on in the Fishfinder menu be sure to go into Transducer Setup and set these parameters correctly otherwise Heaving Compensation will not work right.
