TZT12F/Simrad S2009 Question
Ramos
Alright, long time Simrad user looking at outfitting a new boat with the TZT12F, Furuno transducer and radome. The Simrad S2009 is paired with a 1kw Airmar transducer and will be moved from the current boat to the new boat. We use this FF & transducer for deeper rockfish. The TZT12F would be paired with a yet to be determined transducer for use in 100' of water, or less. The S2009 is a portrait oriented fish finder (not an MFD). Currently, we are able to create a mark on the S2009 and have it show on the Simrad MFD via NMEA2000. My question (finally) is, will we be able to do the same thing from the Simrad S2009 to a Furuno TZT12F?
Forgive me, I'm not very technical when it comes to computers. I don't see anything listed in the manual for PGN. When I go to the Simrad website, there's a whole wad of them. I did a copy and will paste below.
NMEA 2000 PGN (receive)59392 ISO Acknowledgement59904 ISO Request60928 ISO Address Claim126208 ISO Command Group Function126992 System Time126996 Product Info127237 Heading/Track Control127245 Rudder127250 Vessel Heading127251 Rate of Turn127257 Attitude127258 Magnetic Variation127488 Engine Parameters, Rapid Update127489 Engine Parameters, Dynamic127493 Transmission Parameters, Dynamic127503 AC input status127504 AC Output Status127505 Fluid Level127506 DC Detailed Status127507 Charger Status127508 Battery Status127509 Inverter Status128259 Speed, Water referenced128267 Water Depth128275 Distance Log129025 Position, Rapid Update129026 COG & SOG, Rapid Update129029 GNSS Position Data129033 Time & Date129038 AIS Class A Position Report129039 AIS Class B Position Report129040 AIS Class B Extended Position Report129041 AIS aids to Navigation129283 Cross Track Error129284 Navigation Data129539 GNSS DOPs129540 AIS Class B Extended Position Report129794 AIS aids to Navigation129801 Cross Track Error129283 Cross Track Error129284 Navigation Data129539 GNSS DOPs129540 GNSS Sats in View129794 AIS Class A Static and Voyage Related Data129801 AIS Addressed Safety Related Message129802 AIS Safety Related Broadcast Message129808 DSC Call Information129809 AIS Class B “CS” Static Data Report, Part A129810 AIS Class B “CS” Static Data Report, Part B130074 Route and WP Service - WP List - WP Name & Position130306 Wind Data130310 Environmental Parameters130311 Environmental Parameters130312 Temperature130313 Humidity130314 Actual Pressure130576 Small Craft Status130577 Direction DataNMEA 2000 PGN (transmit)126208 ISO Command Group Function126992 System Time126996 Product Info127237 Heading/Track Control127250 Vessel Heading127258 Magnetic Variation128259 Speed, Water referenced128267 Water Depth128275 Distance Log129025 Position, Rapid Update129026 COG & SOG, Rapid Update129029 GNSS Position Data129283 Cross Track Error129284 Navigation Data129285 Route/Waypoint Data129539 GNSS DOPs129540 GNSS Sats in View130074 Route and WP Service - WP List - WP Name & Position130306 Wind Data130310 Environmental Parameters130311 Environmental Parameters130312 Temperature130577 Direction Data
