TZT vs TZTL build quality
Great format for getting my pre-purchase questions all sorted out.
The TZT seems to have been designed for surface OR table-top mount while the TZTL was originally designed for surface mount only (the gimballed stand looks to be very much an afterthought). i am wondering if the TZTL will stand up as well as the TZT to the many times it will be set up, taken down, stowed away, set up etc. As i have not had the opportunity to see either of these in the flesh, i would really appreciate an opinion from folks who have and, especially from owners of the TZTouch2/TZTL.
thanks in avance :think
Hermank,
Each of TZT and the TZTouch2 has advantages over the other. The TZT9/TZT14 already comes with a supplied Bracket/Assy, and their cabling would be the easiest to remove for this unit.
The TZTouch2 line was originally designed for a flush mounting applications, So you must purchase a Bracket/Assy separately for both of the TZTL12F/TZTL15F units if you want to dash mount these units. Also keep in mind the TZTouch2 comes with extended pigtails for NEMA2000, LAN, USB, and the Video Input/Outputs cables.
Thanks for that
how about trim around the unit to prevent damage when taking it on and off the cradle and into/out of storage etc.
thanx again
h
Hermank,
Both units are built to good high quality, so that there is no risk of damage from removing these units repeatedly from their Mounting Bracket/Assys.
