TZT GPS Antenna
  • Thread starter Thread starter zundels
Z
zundels
Will a TZT recognize and be able to use a GPS antenna from Garmin? I would like to use a Garmin GPS 19X instead of the Furuno GP330B because of the faster update rate (10HZ vs 1HZ). Both antennas can be connected via NMEA 2000.
The Furuno would be 1 HZ. For boats it make no difference, unless you are trying to use inferior COG in place of real heading information (which Furuno doesn't do).
Yes, you can use any NMEA 2000 GPS sensor with the TZT, that you wish.
