Tz2 touch
Status
Not open for further replies.
Imraan
Hi
Can you link the 1150 to the tz2 ,so you can view what is being displayed on the 1150 on the tz2 touch
How can you get the gps reading on the 1150
It worked by network with the NN3D and TZT. Japan hasn't officially committed to compatibility of the FCV1150 with TZT2. At this stage I can tell you it appears to work and doesn't explode yet officially not supported, yet.
GPS data would normally be wired in on J2 - Pin 3 (+) and Pin 4 (-) from a 0183 NMEA data source. If you have existing NMEA 0183 data on the boat you could wire it with some simple twisted pair wire. If you need a GPS, I would suggest the Furuno GP39 using the WHITE (+) and BLUE (-) NMEA output wires to the FCV1150.
I have also a tzt2 and a dff3d and a Hub plus the FCV 1150, can you let me know if and how to connect the fcv 1150 to display on the TZT2 please?
Status
