B
Banjeryak
Hello all,
Looking to set up an electronics package for a new boat.
Fishing will mostly be in Long Island Sound. Depths 2-200', most often fishing in <80' of water. 70/30 mix of bottom fishing/mid water column (finding new/overlooked/small/ bottom structure is very important to me). Ideally I'd also like to be able to mark bottom in shallow water as well - say 2' or so - for navigation purposes.
Current plan is: 1 Tzt2 15" , 1 tzt2 12" ( or Suzuki equivalent when available ), B60 through hull transducer, Dff3d black box, 165t-tm54 or 165t-50/200 TM260, DRS4D NXT radar, VHF, pg700, and an MCU-004 remote. This equipment will be going on a 23.5' power catamaran.
Questions: Is the B60 a good choice for this application?
Which transom mount 3d transducer makes more sense, would it be worth it to have the redundancy of the combo 50/200 one ?
Mainly interested in the DFF3D for finding and marking structure ( side scan / history view I suppose), will this setup work for this?
Can I view input from multiple transducers on one MFD?
Can the B60 be run simultaneously with the TM54 ?
Thanks in advance for your responses.
