Trails are not recording
  • Thread starter Thread starter severnriverbricks
S
severnriverbricks
Happy Friday - I have a new TZT3 12 - had it since March - great unit - definitely as easy to use as all the hype. So I took delivery of my boat in early May - then in late June I started to get an error that said no more storage for trails. Ok - I googled around and found instructions that pointed me in the right direction - so I deleted existing and set it to automatically delete the older trails. The error went away but no new trails are being recorded. Was interesting the existing didn't delete - I thought it was just going to delete the oldest one. So I went back in and turned off the delete oldest and did delete existing again - this time all my old trails were deleted but no new trails are showing. So I went in and did a reset to default for trails. Still no love.. I did notice on my map my boat icon has a little red arrow on it that seems to indicated which way I'm turning - not sure what that is.. I do not recall seeing this before all this started. So not sure if its related. Any suggestion on how to get my trails working again?
It sounds like you might be hung up with two different settings. One is to turn On/Off track recording and the other is to display/hide your tracks from being displayed. Ensure you have track recording ON and the display of tracks ON and it should work for you.
You might know this, but i didnt. All you need to do in tap the actual little red boat icon you mentioned. Then the option comes up for track on and off as well as the heading lines etc. I stumbled across that after using my unit for a month or so. Each chart is different as well and I believe that each one of your favorites if it has chart saves these options individually. But im still figuring that part out.
