No the internal GPS is fine as long as it is getting a good fix.  You can check how good the fix is using the SAT monitor screen.  Target analyzer only requires good GPS data to function. So when you are on the full screen radar, you swipe up from the bottom to your radar settings, yet the Target Analyzer setting is not at the top left side of the swipe up?  (above bird mode)
