Suzuki engine data
saltyxcape
Setting up Suzuki engine data on TZT3/NMEA2000. When trying to change the engine data screen I only have 3 choices - oil pressure, RPM, and Temperature. And the display shows Engine and Engine 2, would like to change those to P and S. The sensor list shows the engine interface cables and C10s. The C10's show all the data, trim, gph... Would like to show trim, gph onTZT if possible and mpg.
As far as naming your engines have you done this..
You should be able to show engine trim and fuel rate on display which is included in PGN127489 after doing the auto setup with engines on.
If they still do not appear after you did automatic engine setup, the detail of PGN contents are needed by tech support to verify that it has valid value coming from your engines. You can take a NMEA2000 log file now with the TZT3. You do this using USB drive.
You would want to record the NMEA 2000 bus while running engines and then send the file into tech support to have the data checked.
