I have a TZT3 16, a Vesper Cortex, a 300 NavPilot, and an SCX20. I want to use the SCX20 for GPS, heading and other “location” PGN’s for both plotters and the NavPilot. I will also add a TZT3 12 within the month. Within this setup, how should I set up the device instancing? My confusion arises from comments on this forum that changing the device instance on the CP from zero can create an issue. However, if the device instance of the CP’s are zero, wouldn’t that cause their GPS readings to take precedence over the SCX20, regardless of what the SCX20 device instance is defined as? What is the proper setup for these four devices?
