I've just uninstalled a navnet VX2 system and are fitting a used NN3D system to my Nordhavn 43.
It currently has a ETR 6/10N sounder. Is there any way of this working with NN3D.
If not, would the DFF1 be a straight swap?
Also one of my MU155c monitors won't give an image with a DVI signal, but will work with a VGA signal.
Can I use the 2 MU155c monitors with the MFDBB if I connect them with VGA cables and DVI-I to VGA adapters?
Thanks Andrew
Thanks Andrew
