Sometimes see bottom, but as thin line
I have a 620 machine that has worked flawlessly for several years, but this past week it started showing bottom as a thin blue line, then many times does not show bottom. I fish the same areas every day and usually the bottom is wide and orange.
Madmescan,
Are both frequencies weak? If so, you could reset the 620 to it's default settings? If it is still weak after that I would suspect the transducer.
