Slice BBWGPS WAAS/GPS cable
Hello,
I need to splice the GPS cable for a Navnet vx2 C-map max. The cable is not like the RG8 style cables I see in other posts. It has a collection of 5 or so wires. Can someone provide me so good detail on how to splice this connection back together (had to cut the cable when working on t top as it went into radar arch and I could not get the cable pulled through). I believe it is the BBWGPS WAAS/GPS antenna. Thanks! Zack
If the cable had to be cut it would be spliced back together color for color. If the end of the cable was lost and using a 7 pin NMEA cable the splice would be the same (color for color).
OK that makes sense. Are there good connectors to splice these little wires together? Do I just solder the wires together and weatherproof? Thanks, Zack
