Z Zacanator New member Jun 1, 2020 #1 I have read that GP1971F will convert to loran TD's. I been unable to find the setting to change from lat/lon to TD's. Can anyone help? Thanks
Johnny Electron Administrator Staff member Jun 5, 2020 #2 You first must know that Loran C numbers is only available for select areas on this machine. See the link below for available areas and settings. https://www.furunousa.com/-/media/sites ... chains.pdf You can setup the GRI and station information under HOME - SETTINGS - NOTIFICATIONS -LORAN C. If that doesn't allow you to turn them on for display, check under the units menu. HOME - SETTINGS - UNITS - FORMAT AND REFERENCES - POSITION FORMAT
