I'm installing a DRS4D on a bracket on the front of our mast. I assume it will need a sector blank for the portion of its sweep that includes the mast. How wide should this sector blank be? Is setting it for just 180* enough, or set the range to cover the center of the antenna sweeping past the 6" of mast section, or does it need a large range that includes the whole 24" of antenna sweep across it? If the latter, then it seems like there will be no radar transmit/return for ~50% of the antenna sweep, and the blind spot will be huge. Even setting a range to clear 6" of mast section, the trig works out to a 30* blank sector.
Mark
Mark
