Interconnection diagrams are either in the back of the Installation Manual or if there isn't an installation manual...the back of the Operator's Manual. Here are links to both:I want to connect SCX21 to my RDP149 display (my radar is 1944C model), please show me a interconnection diagram. Thank you
I found a wiring diagram of SCX21 and RDP 149. It seems pin 3 and 4 (TD1-A and TD1-B) of SCZ21 will connect to pin 1 and 2 port 3 of RDP149. Please advise. Thank youInterconnection diagrams are either in the back of the Installation Manual or if there isn't an installation manual...the back of the Operator's Manual. Here are links to both:
SCX21- https://www.furunousa.com/-/media/s...als/public_manuals/scx21_operators_manual.pdf
1944C- https://www.furunousa.com/-/media/s...18x4c_19x4c_gp1920c_installation_manual_k.pdf
Based on what you stated above, it appears that you are connecting the SCX21 to provide heading information to the RDP149. If this is true, the best port to attempt connection without having to change any settings in the SCX21 is:I found a wiring diagram of SCX21 and RDP 149. It seems pin 3 and 4 (TD1-A and TD1-B) of SCZ21 will connect to pin 1 and 2 port 3 of RDP149. Please advise. Thank you
Yes, I want to upgrade heading data for my radar. I am using PC-500 for my radar and I am using furuno sonar for my fishing boat too, I want to get a stable heading signal. I will let you know after I finish. Thanks so much for you helpBased on what you stated above, it appears that you are connecting the SCX21 to provide heading information to the RDP149. If this is true, the best port to attempt connection without having to change any settings in the SCX21 is:
SCX21 - Data 3 -------------RDP149 Data 3
Pin 9 - wht/gry (TD3-A) ----Pin 1 (HDG-H)
Pin 10 - blu/gry (TD3-B) ----Pin 2 (HDG-C)
Let us know if this works.
Yes, I am looking for a GP39 display to set a correct MNEA version on SCX21, it is really hard to find it. It is said that SCX21 can setting by computer ( I read SCX21 maunal), can you help me on this? Thank youI think it's more likely the NMEA v4.1. RDP149 used v1.5 and 2.0. If baud rate is wrong, that would definitely be a problem too. Would have to get in the SCX21 settings and change baud rate, NMEA sentences and/or NMEA version to get it to work over there. Also, in RDP149, would need to go to Menu-System Configuration-Nav Option-Nav Source Settings and ensure the "position source" is set to "All".
Yes, AD10 is not available on SCX20. That's why ARPA wasn't working with it.I found the GP39 and set the baud rate (4800 only) and MNEA version 2.0. GCX21 can works with my 1944C well , It got heading (data 3) and posstion at data 2. But it has new problem, my radar can not caught a target (I changed to my PG500, it can). is there any different between PG500 heand and CSX21 heading? I think the heading I got from SCX21 may be MNEA data (not AD10) so my ARPA doen;t work, right?. This is my GCX21 data 3 seting:
Format: MNEA0183 V2.0
Talker: HE
Baud rate: 4800
Sentences: Default setting (see my attachment)
Yes, it'll work with a 1945 radar. Recommend 25ms HDT from SCX21I got it, but will SCX21 work with 1945C (RDP150)?
Yes it work but 25ms HDT can be work with 38.400 baud rate, so I choosed 1945 for my boat though I like my 1944CBB so much (large and beautiful display). I am appreciated for your help so muchYes, it'll work with a 1945 radar. Recommend 25ms HDT from SCX21
Yes, I reset the update rate and It worked. Thanks so much for you helpAgreed the update rate is set too slow so the NMEA heading isn't accepted for ARPA. Set the update rate of heading faster.
