Installing new furuno suite and would like to install SCX 20 in front of radar gearbox but wod like to confirm that the array when rotating when it passes over SCz it won't cause signal loss. With a 6ft array that eats up a good bit of real estate if GPS can't be underneath swing of radar antenna.
I understand the ABYC standards which calls for like 6m between every electronic device and mounted on different elevations.... In real world application is proximity to gear box or swing of array ok when radar is on or will this impact SCX performance? SCX will NOT be on same plane as array which I know can cause issues.
