SCX-20/sounder
CAPTDEVONC
Having issues with my sounder(no sounder) after updating the machines and sounder module.The new ant. does not function properly as well , I cannot set the preferrnce to 001 like I was instructed .
any help , thanks
Hey,
Not sure what update you just did but if you did 6.21, make sure you go into the [Sounder Menu] and go to the bottom of the menu and reset the hardware and sounder settings. After that, make sure the sounder source is set to your sounder and then complete the transducer setup.
The new ant. does not function properly as well , I cannot set the preferrnce to 001 like I was instructed.
Are you trying to change the instance number on your SCX20? If you are, you can do it by going into Home > Settings > Initial Setup > Sensor List, tap on the keyboard by the instance number and change it to the preference of what you would like the SCX20 to be.
