I am looking into this. I experienced the same NG result as you. I will reply back when I have more information.
Yes, though it is a minor update. It should be sorted out today and available online tomorrow.I had the same experience. It seemed to me upon closer examination that the newly released sensor update package that has the radar update had the wrong SCX-20 version. Fortunately it did not corrupt mine, it just failed to install.
Is there actually supposed to be an SCX-20 update?
FishTech,
The file you e-mailed me loaded fine. Versions loaded were:
Application: 02.01 OK
GNSS_Core: 01.02 OK
Thank
Where I can donwload the files?FishTech,
GNSS_Core: 01.02 OK
Thanks!
The software posted on the web should be good now. I sent you a copy just in case your copy was corrupt.Where I can donwload the files?
Basically, it was updated to prevent output of last stored heading on power up. This prevents erroneous heading from being provided and doesn't output heading until the SCX20 acquires it. This happens relatively quickly anyway, so you may not notice any difference.Where are release notes posted?
I do not want to update if it is not needed....
Yes, version 2.01 is available and you are 1 version behind at v1.06. Software is available on our website for updating via a Sensor Update using the TZ Touch series. Please see response above as to what the update provides.Hello, I have an SCX20 and I am wandering if there is a new update for it.
I am having issues with the sensor not fully populating the heading PGN for the first 3-4 minutes.
If there is how do I get the code and upgrade it because the only Furuno instrument in the boat is the SCX20.
I would really appreciate any help.
Astolfo
