Quitsa
My 711C autopilot has developed an odd problem. The rudder position suddenly went to a large out of range value. After checking that nothing had come loose in the sensor mounting and that the wire connections at the processor were solid, in desperation I did a factory default reset and redid the installation setup. The rudder position went back to normal values and functioned normally. However, I left the system on and after about 15 minutes, the rudder position was again showing as an out of range value, which doesn't change at all as the wheel is moved.
The autopilot has worked well for three years. I don't really understand how a simple potentiometer like the rudder sensor could fail in this intermittent way. Any thoughts as to what I could check? I tried measuring the resistance of the RRU and it seemed in line with specifications.
