proasegler
I have bought a used RSB 0093 Antenna as a replacement for my flooded one. On the bottom of the dome unit there is a small hole with a hose ?? coming out about 5cm. Is this made by the factory and what is the pupose? I also found some salt cristalls inside the dome. Should I be concerned? There is no corrosion on the electronics and wires so far. The dome cover and seal are like new.
Thanks, Peter
Thanks, Peter
