RRU cabling
MVStillwater
Continuing my 711C installation, I have a question about the cable for the RRU FAP-6112. How important is the cable shielding for this unit. I have existing unshielded wiring that would make installation much easier. Does anyone know how susceptible the RRU is to interference? Thanks in advance for any experience.
Thanks for the reply - it's hard to argue with that :). What I'll do is try the existing wiring since that will be easy, then run some tests with everything running, including AIS and transmitting on the VHF.
I ended up being able to install the RRU with the supplied cable after all. So no compromise on the shielding. Thanks again.
