I have a vx2 RDP 149 with a rsb-0700 1944c Radar. After warmup and pressing transmit I get a no heading pulse and no direction pulse. I was getting no rotation of the array and could not hear anything. Check all connections and also spoke with a rep and insured system is setup properly. One thing that is odd and the rep was unsure of is with the unit in tx mode I only have power at a single wire. A green wire that we said was a spare. I checked all grounds etc. found a spot in the cable I thought may have been nicked. I cut it completely through there as I only need 10’ I figured I would test power at each wire prior to putting them in the clips. The connection to the unit looks great no corrosion. Turned the unit on and to TX and went through every wire in the bundle and again the green wire is the only wire that has power. Any idea of what would cause this rep said it’s a spare so is there an internal fuse for the radar output.? :sorry According the scamatic There should Be several more wires that are energized. I can get another radar if need be but would like to make sure it’s not the unit itself but that’s what I’m starting to believe not getting power from the RDP 149 to go to the radar. Any And all advise or ideas are welcome, please let me know as I’m currently At my Witt’s end :angry with this and don’t know where to go next.
