Do you have one of the old style memory cards? If you do, it could be saved to that and then sent to tech support and they should be able to get it off and convert it for you. Normally if you don't have that older style memory the best way is to connect up the NN1 with a Vx2 and copy them over the network. Then save the files to SD card in the Vx2. The TZT2/TZT3 have a built in converter to convert that format to the newer type. Getting it out of the old NN1 into a more standard media format is the hardest challenge.
