Radar
The 1715 radar comes with the RSB0095-076 18.1 Inch dome.
The signal cable is part number 001-122-790 10 Meter Signal cable, but longer lengths are available.
I take it nothing else works? No interchangeability or cross reference?
I found a used one online on top of a mast. I think the cable has probably been cut. Can you buy a plug and wire the cable to the right pins?
You can buy the nine pin white connector and pins at the scanner end from your Furuno dealer. If the connector at the display is damaged, you must replace the cable.
