Hello,
I have a Navnet VX2 1834 with C-Map. I purchased a used PG500 so I can get radar overlay.
It is mounted midship at about the waterline. I cleared memory and then did a calibration. However after 5 or 6 circles it would still not calibrate. It was mounted on a small piece of aluminum so I moved it about 2 feet forward so that is not near any metal.
After moving it I was able to calibrate after 3 circles. I now have Auto and Status LED lit.
However my overlay seems to be 15 to 20 degrees off and is worse going south compared to north. Are there any other adjustments I need to make? I tried re-calibrating with about the same results. I have attached a picture of the overlay to show the offset.
Also can you tell me what the faint green line is to the left of my track is?
Thanks!
Thanks!
