Pin Out for MJ6 to RJ45 Network Cable
Entropy
I am in process of upgrading firmware on RPD-139 on an older boat located outside US. I need to make up a network cable to connect the Display (MJ6 6 pin) to Laptop with RJ45. No Furuno factory MJ6 to RJ45 cables on Island but have located a used MJ-A6SPF0014 with an MJ6 6 pin end and have standard Ethernet cables at the local Computer store.
It will be a direct connection between the laptop and the RPD-139 Display as there is no network hub. Therefore the cable will need to be a cross over.
Does anyone know the pin out for a cross over connection with MJ6 6 Pin and RJ45 Connector?
Andrew
Good morning Andrew,
Please see the diagram below that shows the pin-out of the Network port on an RDP-139.
You will want to make the following:
RJ45---------------------------------MJ6
3---------------------------------------1
6---------------------------------------2
1---------------------------------------3
2---------------------------------------4
Also below is a link to an update instruction document for Navnet 1
https://www.furunousa.com/-/media/s...oftware/navnet_loader_software_addendum_2.pdf
Kind Regards
C-Bass
