When on the water in a fixed position like tied up on the dock, the PG700 is typically reading 5 degrees less than the Ritchie compass. The Navpilot is set to Magnetic in the Heading Display.
When parked in the garage (which is a pre-fab metal building), the difference is 37 degrees. There is no electrical equipment near the boat, the floor is concrete and is the closest to the PG700 at 3 feet. The building walls and ceiling are 7 feet or greater away from the PG700 and compass. The compass is probably a minimum of 7 feet from everything.
The PG700 and compass readings do not change in the garage when the boat's electronics are powered up or when shore power is connected. The PG700 reads 332 degrees and the Ritchie compass reads 9 degrees pretty much all the time in the garage.
I can see how the metal building would affect the magnetic field but not along the lines of 32 degrees (37-5=32). There is no problem here, just curiosity. Everything works fine on the water. Any ideas, and should I at least adjust the compass offset 5 degrees in the Navpilot?
