Has anybody tried to install an Omnisense Ulysses micro IP cam on the TZT3 MFD? I can't get the video stream to show up even though the cam is recognized. The can works great on a laptop but not the MFD.
Thank you Kraken! I did follow that guide. My issue is that the camera works great on the laptop during setup. When I connect to the TZT3 it recognizes the camera is there. It even put it's own icon on the menu. When I touch the screen on the camera menu it will pop up a red circle around my finger but no video stream. Then, I will get this message, "There was a problem decoding or connecting to the camera stream Please verify the camera setup". I also followed this document: https://www.furunousa.com/-/media/s... with third party devices via Ethernet. These
There are some discrepancies in the IP configuration between the two documents. I tried all of those IP addresses with the same results. No video stream from the camera. I checked the firmware on the TZT3 and the Omnisense micro camera. Also, what is not mentioned is the IP subnet and default gateway settings.
