Home - Settings - Initial Setup - Service
Password FURUNO SERVICE, all upper case with space in the middle
Once in the service mode "Cancel" the first popup window for the factory PIN and then go to the UTILITY tab. Select "SETUP" of the factory Default. When the reset menu appears, choose ODOMETER from the pull down and then choose RESET>ok>ok>Exit>Power OFF
