I’ve had this problem for awhile. Whenever I power on my 711C it goes into “demo mode” and I cannot get into the menu or anything. When I press any button I get two beeps and that is all. I decided to update the software to the current version to see if that might correct this problem. I was able to successfully update the processor software to V1.27 but when I attempt to update the controller software I get “controller missing” messages for all 6 controllers. So it appears the controller and processor aren’t communicating with each other. I’ve checked the connection on the back of the controller and even tried reversing the cable connection and the terminator with no luck. I’ve checked the wiring into TB8 on the processor and to be sure I removed the wiring, cut, stripped and re-inserted into the wiring block to make sure there are good connections. Still no luck. I also tried moving the jumper for TB8 to 3/4 and plugging the controller into the B port and still no luck. It always boots into demo mode and each time I attempt to update the controller software I get the “controller missing” messages for all 6 controllers.
Has anybody had this issue and been able to come up with a resolution. Any help would be appreciated. Thanks in advance.
