		All's Well
I recently ordered a Furuno DRS4D-cm radar set-up that should connect with a RJ45 Ethernet connector to a standard PC running Time Zero software.  A few questions:
1. What cables should I expect to receive with the unit?
2. What is the amperage requirement for the Radar set as it relates to wire size and circuit breaker, the vessel is 24 volt?
3. Will I be supplying the cat. 5 cable for the connection?
4. Is there any technical information on the Furuno web site for this model, manuals?
5. Will this unit allow me to not only connect an Ethernet cable, but also a NMEA 2000 connection to communicate with the balance of my network?
Please let me know any information you may know.
Thanks, Cyril
Thanks, Cyril
