Hi, I just instal a new TZ2 with NAVPilot 300. Finish all steps to adjust all but when try to use autopilot receive a alarm “no GPS position”
I see all sensors and units.
Please give me a advice what to do
you need to go to your NMEA2000 output PGNs under the initial setup on your TZT2 - there you need to make sure that GPS position is sent out - under this section you will see all the sentences that can be sent out - select all the relevant sentences required for your autopilot.
