SailorBruce
I know that "weirdness" isn't a very accurate technical term, but it is the best way I can summarize what I'm seeing. Frankly, I'm at a loss....
System: NN3D w/ 3x MFD12, DRS12A--GP-330B, FA-50....
I recently fired up the radar and did not get the the normal returns from the buildings around my slip. I should note that since I had last used the radar, a lot of troubleshooting had taken place for different issues. One of those troubleshooting steps involved me desparately hitting "restore to default" whenever I came across the option. So, I'm pretty sure that this issue is self-inflicted.
At any rate, the system now doesn't seem to see any of the obvious walls and buildings. It does seem to see antennas and other tall features. If I turn up the gain to 100%, and turn down the sea state filters, I can see antenna towers in the distance, and the sweep of the antenna. If I keep everything set to "auto" nothing appears on the screen at all--at any zoom level. Eventually, the system throws a "tuning error."
This may be a red herring, but I seem to hear more noise than I recall while the array is spinning. Sort of a "clunk, clunk" for each revolution. This may somply be that I don't usually have the radar running when the engines are off, but thought I'd mention it.
Any troubleshooting ideas? I'm in the middle of a winter cruise down the ICW and would like to have my radar back for low-visibility days.
Thanks in advance!
Thanks in advance!
