If you did your own install, you would contact your local authorized servicing dealer for assistance. If it is a problem due to installation, it will be on you to cover. If the unit is under warranty and it's a factory defect, then Furuno pays the dealer. You still have to be within a certain distance from the servicing dealer because there are obvious limits. If you have no dealer near you, you would either need to move the boat closer to them or pay the overage of travel. This is where having the work originally installed by a dealer is helpful. If the install was a problem, they cover their work. It is also easier to get a dealer to put you on their schedule sooner when you are their customer. If you are a US customer, you will find a link at the top of the website that says "Where to buy" it will list all the dealers in your area. You can contact the nearest servicing dealer to arrange service. If you are not a Furuno USA customer or you are traveling, you can find the local distributor for other countries via Furuno.com.
